Topic: Digiface USB pops and glitches on Windows 11
I have a brand new Digiface USB that I attached to my Hp 15-cx0002nl laptop. It has a i7-8750H cpu with 16GB of RAM and Windows 11 OS, so a good amount of power.
When setting buffer size to 128 and below I experience lots of clicks and pops, even with just the headphones active on main system audio.
I checked lots of guides about LatencyMon and such, had some improvements in latencies but clicks are always there.
I need that low buffer sizes because I'm using virtual instruments with usb keyboard, so I need the least amount of latency possible.
I updated all possible drivers that I found.
Here's the output of LatencyMon:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:01:05 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: LAPTOP-MPCQ85KE
OS version: Windows 11, 10.0, version 2009, build: 22621 (x64)
Hardware: HP Pavilion Gaming Laptop 15-cx0xxx, HP
BIOS: F.28
CPU: GenuineIntel Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 16264 MB total
CPU SPEED
Reported CPU speed (WMI): 2208 MHz
Reported CPU speed (registry): 2208 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 3192,60
Average measured interrupt to process latency (µs): 7,075660
Highest measured interrupt to DPC latency (µs): 3177,40
Average measured interrupt to DPC latency (µs): 2,140893
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 3,250906
Driver with highest ISR routine execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000042
Driver with highest ISR total time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,000042
ISR count (execution time <250 µs): 139
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 3182,343297
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0,010860
Driver with highest DPC total execution time: ndis.sys - NDIS (Network Driver Interface Specification), Microsoft Corporation
Total time spent in DPCs (%) 0,027752
DPC count (execution time <250 µs): 33193
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 117
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 1
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 1245
Hard pagefault count of hardest hit process: 583
Number of processes hit: 21
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1,244395
CPU 0 ISR highest execution time (µs): 3,250906
CPU 0 ISR total execution time (s): 0,000328
CPU 0 ISR count: 139
CPU 0 DPC highest execution time (µs): 3182,343297
CPU 0 DPC total execution time (s): 0,192413
CPU 0 DPC count: 27870
CPU 1 Interrupt cycle time (s): 1,361831
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 67,337862
CPU 1 DPC total execution time (s): 0,001051
CPU 1 DPC count: 156
CPU 2 Interrupt cycle time (s): 0,717576
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 65,714674
CPU 2 DPC total execution time (s): 0,013726
CPU 2 DPC count: 2369
CPU 3 Interrupt cycle time (s): 1,430560
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 19,543478
CPU 3 DPC total execution time (s): 0,000950
CPU 3 DPC count: 191
CPU 4 Interrupt cycle time (s): 0,430539
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 65,832428
CPU 4 DPC total execution time (s): 0,002201
CPU 4 DPC count: 474
CPU 5 Interrupt cycle time (s): 0,628204
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 12,807971
CPU 5 DPC total execution time (s): 0,000066
CPU 5 DPC count: 27
CPU 6 Interrupt cycle time (s): 0,420647
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 17,963768
CPU 6 DPC total execution time (s): 0,000799
CPU 6 DPC count: 233
CPU 7 Interrupt cycle time (s): 0,415147
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 39,580616
CPU 7 DPC total execution time (s): 0,000572
CPU 7 DPC count: 136
CPU 8 Interrupt cycle time (s): 0,401459
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 72,866848
CPU 8 DPC total execution time (s): 0,003739
CPU 8 DPC count: 913
CPU 9 Interrupt cycle time (s): 0,376544
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 0,0
CPU 9 DPC total execution time (s): 0,0
CPU 9 DPC count: 0
CPU 10 Interrupt cycle time (s): 0,409884
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 15,528986
CPU 10 DPC total execution time (s): 0,000481
CPU 10 DPC count: 132
CPU 11 Interrupt cycle time (s): 0,385805
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 66,139493
CPU 11 DPC total execution time (s): 0,002448
CPU 11 DPC count: 811
Hope someone can help me track the problem,
Thanks,
Frank
