1 (edited by Derp 2023-01-19 19:32:39)
Topic: Dirac compatibility
Good evening,
I've been researching for a bit but cannot figure it out to save my life.
Let me preface this by saying that I own an ADI-2 DAC FS as my desktop device and particularly appreciate its dynamic range and loudness feature set. So I am somewhat superficially familiar with the device.
I have considered to rework my living room somewhere down the line and been laying out options. Ideally I'd like to "future proof" in terms of feature sets, insofar they are, at all, compatible. A second ADI may thus be on the menu.
The chain, in my mind, would generally look something aching to this:
TV (SPDIF)/BT Receiver(SPDIF)/PC (USB)/... -> RME ADI-2 DAC FS (Pro) -> (Power Amp) -> (Stereo Active Speakers) / Active Speakers
Now my question is, whether a dirac device (DDRC-22D / DDRC-24 depending on the chain placement for example) would be compatible without losing either the ADI's Loudness/Dynamic Range feature (ADI would connect into the minidsp) or the dirac feature (minidsp would connect into the ADI).
Can this feature set be stacked or will one DAC effectively "override" the other? The chain would be kept entirely digital throughout. Assuming they could be stacked, should dirac or the ADI be the preprocessor?
Concretely:
TV -> DDRC-22D -> RME ADI-2 DAC FS -> (Power Amp) -> (Stereo Active Speakers) / Active Speakers
vs.
TV -> RME ADI-2 DAC FS Pro -> DDRC-24 -> (Power Amp) -> (Stereo Active Speakers) / Active Speakers
Dirac doesn't hold any particular value to me right now but it may in a few years time so I want to verify whether this is even possible or is a fool's errand.
In case it is a fool's errand (a very a costly one at the very least): I also got a decommissioned raspi 4 laying around, if that seems more feasible but would require some key words/hints to get me started walking down the correct path.
Thanks.
2 (edited by KaiS 2023-01-19 23:15:49)
Re: Dirac compatibility
DIRAC is a problem fixer.
What’s the problem you like to fix?
If it’s about room acoustics, don’t expect too much beyond what ADI-2 can do.
Room acoustics is more a time domain problem, think “Echo”.
Dirac (and other equalizers) work in the frequency domain only, leaving the echo untouched.
EQ’s are very good in fixing mis-tuned systems, or re-tune a system to a personal preference:
more or less quantity of bass or treble or midrange, in great detail.
But they cannot remove wall reflections, “Echoes”.
It boils down to invest personal time into speaker placement, even selecting a speaker that fits to a room, or fit the room to the speaker.
Example 1:
You have a room with lot’s of reflective surfaces, like glass and naked walls.
If your speaker has a controlled, high directivity, focusses it’s sound more on the listener and less on the walls, less reflections will be produced, you get a clean sound.
Example 2:
Your speaker has a wide dispersion, spreads the sound all around.
You have treated your room with some absorbing materials like carpets, curtains and drapes, maybe a filled bookshelf and textile seatings.
Again, you get a clean sound.
It’s about pairing, and there’s not much an EQ can do if the pairing doesn’t fit.
What EQ can do:
Give some retouch to an otherwise well-paired and optimized system, bringing the quality a notch or two up.
Remove little annoyances, that stick out more if everything else is already on a high level.
There’s one area where it’s just the other way round:
Headphones.
With headphones it’s very much about frequency response tuning, time domain is clearly dominated by it, simply because much less is going on in the time domain of headphones.
For headphones an EQ can make a night and day difference.
3 (edited by Derp 2023-01-20 06:27:09)
Hey,
thanks for the reply.
Right now, in regards to dirac or EQ, none, really. Our living room is relatively long and narrow, maybe ~2.5m speaker distance at best.
I am mostly looking to throw out my NAD C368, as I personally do not think it does my pair of Dual CL730's any justice (I am  a bit of a grave digger). Further I had hopes for a NAD HDMI 2.1 MDC Module but it is 2023 now and I am not about to hold my breath.
Prior to setting up the Duals in the living room I had them hooked to my desktop for a little while using an ADI and Topping PA5. They sounded rather brilliant, at very least in contrast to the NAD.
So at the very least I'd like to ditch the NAD, pick up another ADI and reinstall the PA5, for as long as the latter may live, as apparently there have been some potential production issues with them.
The ADI would become the "brain" and volume controller for any active amp or a pair of active speakers, such as a pair of Mackie MRs, which I am also fond of and could work due to the narrowness of our particular living room.
So what about dirac?
Ultimately I would expect another ADI investment to serve me well for years to come, this includes moving to different/various places and situations, which may or may not turn out to be infinitely more complex than our current situation.
Unfortunately I am a bit of an idiot when it comes to sound technicalities overall. I am simple man and I like "good" sound.
So dirac would throw money at a problem that would be perfectly solvable through other means. It would be effectively aching to calling an electrician to have your stove connected: What you cannot or are unwilling to do yourself, you have to pay others for.
Hence this is more of a question of general compatibility first and foremost. I merely want the option of the easy, if expensive, way out, should it come down to it.
If I understood you correctly however, then the ADI would be almost, if not equally powerful in regards to settings and EQ capabilities that it could do what dirac does, albeit with more personal investment.
The headphone amp portion for that setup would be moot, as rarely, if ever used. My desktop been driving a plethora of headphone splendidly though.
This at very least would confirm that throwing an ADI into the living room isn't one of the worst ideas I've ever had and I could always take things from there, should there ever be an actual need for either dirac or dirac-esque corrections.
4 (edited by KaiS 2023-01-20 08:33:12)
As you already know, ADI-2 DAC as the central unit is a fine solution.
If you want to use Dirac, it has to be inserted BEFORE ADI-2 DAC.
This means, source selection (TV (SPDIF)/BT Receiver(SPDIF)/PC (USB)/...) needs to be done in the Dirac unit.
Check, if that’s possible.
Both speakers mentioned don’t need much correction per se, for basic adaptions they have their built-in controls.
Compensating one or two room modes could be done in ADI-2.
An iPhone with the app AudioTools by Andrew Smith, temporarily used as measurement tool would be enough to assist finding the right setting.
So if you buy Dirac it’s really more about expertise than hardware.
5 (edited by Derp 2023-01-20 09:14:51)
Thanks, that was the vital information I could not piece together myself.
Going by today's options a DDRC-22D should work from my understanding, as it comes with digital ins and outs, where the outs would then feed into the ADI.
Whether that device is still around, superseeded or relevant by the time I would actually consider it, is another story but then there may be others, or replacement technologies altogether. So long as it has to go before ADI that is all I needed to know.
Thanks for the clarification and have a fantastic weekend.
6 (edited by WowFlutter 2023-01-20 10:34:58)
Hi, I have been using a DDRC-22D for room response correction since 2018. It works in the frequency, as well as the time domain (impulse response correction).
Having measured the room response once and defining the target frequency response, I found any other frequency domain setting downstream from the DSP (EQ, loudness, tone) is unnecessary.
I have recently bought an ADI-2 DAC and it works perfectly with my setup (of course, as KaiS pointed out, it connects to DDRC's digital output). In this setup, I might not have much use for ADI-2's own DSP and filtering, but ADI-2 DAC has enabled me to better understand the signal coming from the DDRC and adjust the output (ref level and volume) to best match my amp's input stage.
One thing that happens with a DSP like DDRC is the need to attenuate its input in order to compensate for the gain that might occurr during processing, which can lead to clipping. DDRC has four attenuation presets: 0, -3, -6 and -10 dBFS. Before getting ADI-2 DAC, I was never sure whether I was applying too much or too little attenuation - now I can see exactly.
ADI-2 DAC FS
ADI-2 Pro FS R BE
7 (edited by KaiS 2023-01-20 13:41:16)
We are talking about different issues:
Fixing transducer imperfections is possible.
But – it’s physically impossible to remove room acoustics from a signal by any compensation.
The reason is simple:
If you try to compensate e.g. a single wall reflection, the compensation signal causes another reflection by it’s own, that would again need compensation, and so on.
Very bad if the reflection contains frequencies that are louder than the original – happens all the time for close wall reflections.
Then the compensation needs to be louder too, and the compensation of the compensation... - instability.
You get there figures?!
Then, in a real room, you get a large multitude of reflections, from multiple directions, which the auditorial system (ears + brain) can separate from the direct signal by some amount.
You even “learn“ your room over the time.
The measurement microphone can‘t do this.
So measurement and personal reception does not coincide - how could the measurement then be used to get a valid base for compensation?
Furthermore, any compensation would only be valid for one single point in the room, of few millimeters size.
Any deviation from this point renders compensation into error.
Unfortunately we have two ears spaced apart, and we move around...
The above is just scratching at the surface of room acoustics, there’s much more about it, filling books.
I’ve been running through this all through my decades long career, every time new technologies arose we thought: “Now we can trick acoustics”.
Then we though: “Why didn’t this come out like expected?”
Finally you always replace one error with another.
There‘s no way around good speakers, correct placement and a basic amount of room treatment, which may consist from normal furnishings for domestic use.
There‘s a reason recording studios invest on this.
I am quite sure that a great deal of knowledge, effort and money goes into equipping a good recording studio. Dirac is definitely not designed for studios or recording, and not even for monitoring. But it is also not "tricking acoustics" as it is based on recognised research in acoustics and signal processing, and not snake oil. Its correction is based on a signal model which - as any physical model - is a simplified approximation of reality.
However, this model is surprisingly effective in dealing with most domestic situations, where little or no optimisations beyond good speaker positioning can be done for reasons of aesthetics or economy. You will not see bass traps, absorbers or QR diffusers in many living rooms! It can't do wonders - a difficult room will stay difficult, but it does a fair job of reducing most prominent resonant modes and indeed does try to cancel the room impulse response - up to a reasonable amount.
Now the question is the user expectation - it won't turn a concrete stairwell into an anechoic chamber, for sure. But it does help an audiophile get rid of the most annoying imperfections induced by a living room not designed by an acoustic engineer, and allows us to take a step further in music enjoyment.
ADI-2 DAC FS
ADI-2 Pro FS R BE
https://www.dirac.com/live/dirac-live-a … treatment/
Apparently, they are coming with something this year!
10 (edited by xajas 2023-02-06 23:29:36)
I think, this will be somethink what controls active bass traps / double bass array.
I use DBA since years and it works great!
11 (edited by xajas 2023-02-06 23:44:02)
Maybe it is not possible with DDRC/Diarc yet, but you can applay DSP-methods, which resolve some major acoustic issues. And the major, most sever acoustic issuess are the low frequency modes/reflections, which are very difficuld to rediuce with a acoustic treatments. But you can achieve it preaty eficiently using DSP for driving active bass traps (active bass absorbtion). And this have significat impact on behavior in the time domain (RT60, Waterfall, ....)
12 (edited by KaiS 2023-02-07 02:09:08)
To absorb bass energy from a room the absorber needs area and volume.
Volume can be replaced by mass, if you limit it‘s effect to a certain frequency range.
A foil absorber does that, it‘s most effective around it‘s resonant frequency.
I‘ve built studio control rooms where the whole back wall was used as foil absorber.
This way not much room size is sacrificed.
For active bass traps the same premise is valid.
A small absorber does not catch much energy from a room.
Maybe soundfield calculations might help, if an active absorber (which is in fact a subwoofer) does send some compensatory energy in advance.
The regular subwoofer itself could be used for this too.
Will be interesting what Dirac will come out with.
EDIT:
After reading through their press release it seems they come out with exactly that.
Following their announcement you need more than one bass-capable speaker to achieve the desired effect.
13 (edited by xajas 2023-02-07 12:08:08)
KaiS wrote:
T
EDIT:
I think, we should differentiate between two appraches:
1. Soundfield Management  (SFM)-> multiple bass sources loacted in various places in any shaped room sum in one point in room (listening position) through their calculated SPL and delays to a well shaped frequency response. This is described by Welti, Devanitier, Geddes and others.
Advantage: works in any room and "free" subwoofer location
Disadvantage: works for one place, complex soundfield calculation of level and delays
2. Double Bass Array (DBA) -> back subwoofers work as bass absorber (prevent reflection) -> active bass trap
Advantage: works for wider listening area, easier to calculate the setup
Disadvantage: works only in rectangular rooms and requires specific placement of the bass sources (subwoofers)
Long speech short:
in approach Nr.1 all subwoofers are "a source"
in approach Nr.2 front subwoofers are "a source", back subwoofers are "absorber"
I guess, Dirac will follow Nr.1
BTW.
There is a tool "Bass Optimizer" which calculates the optimal setup (SPL/Delays) for multiple subwoofers. I can imagine, that this is this kind of solution, which Dirac is going to use
