1 (edited by Data 2023-01-04 12:11:54)
Topic: Mic preamps in the digital domain
This maybe a stupid question... what is the purpose of having mic preamps when a line level output is never used? I am thinking of products like the RME 12Mic where the signal goes directly into the AD converter, but the same goes for many interfaces with in-built mic preamps. Surely a mic signal can be AD converted directly. Maybe AD converters require a line level signal for some reason? Or does it have to do with optimising SNR?
UCX II, Quadmic II, ADI-2 DAC FS, MacBook Pro (M1 Pro), Logic Pro
2 (edited by ramses 2023-01-04 12:50:03)
Re: Mic preamps in the digital domain
Sorry, I do not get the point of your question, please rephrase.
The task of a Mic preamp is, to bring the low output of a mic to line level.
The 12Mic performs an A/D conversion which is needed to be able to send the data to the recording interface, either through MADI or through ADAT.
Some Mic Preamps have
- either exclusively analog outputs (QuadMic II) or
- ADAT and additionally analog outputs (OctaMic II)
so that you can connect the preamps also analog to another AD converter which are located
- either directly at the recording interface
- or located at an AD converter which is connected to the recording interface via ADAT, MADI, AVB, ...
BR Ramses - UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro22H2, Cub12Pro
3 (edited by Data 2023-01-04 13:13:37)
The 12Mic does not have any analog outputs (not counting the Phone out), so why would a line level voltage ever be required? The mic level signal could go directly into the ADC for conversion. In the subsequent digital domain "line level" does not have any meaning, to my knowledge.
Wait a minute, I have the feeling that everything is getting more and more confused wink
First. Since I didn't understand your initial question, I just summarized some basic things about the topic in the hope that it helps you to collect your thoughts and to formulate your question understandably.
TBH .. I still don't know what you are even getting at or what your problem is.
Has no one claimed
Has no one claimed, maybe there is a misunderstanding from your side
Thats what I told: "The 12Mic performs an A/D conversion which is needed to be able to send the data to the recording interface, either through MADI or through ADAT"
Of course not and has no one claimed.
5 (edited by ramses 2023-01-04 13:47:04)
Maybe I should rephrase my sentence here:
"The task of a Mic preamp is, to bring the low output of a mic to line level."
The output signal of a microphone is so low that a normal ADC could not convert it.
You need a preamp stage to bring it to a signal level where the ADC conversion can take place.
Analog converter have different reference levels as you have not one common signal level regarding connected devices.
From consumer level up to +24 dBu.
I do not know exactly what level is needed by the pure AD converter chip. In a data sheet of the AD9213 I found values in the range of 1,2V which is American studio level (+4 dBu).
The mic signal alone is definitively too low for AD conversion, as it is in the range of 0.001 - 0.01 V.
6 (edited by Data 2023-01-04 13:52:44)
I do not know by heart what exact level is needed by the pure AD converter chip.
But .. the mic signal is definitively too low, it needs an amplification in the range of factor 100 if I remember right.
Thanks, this is the answer I was looking for. So ADC chips are designed to require a certain input voltage (line level, meaning a few volts) to work properly, and if it is too low (mV range) it cannot do a conversion. Didn't know that...
You're welcome, btw I added more specific information to my last posting.
One addy to the discussion:  I prefer those recording interface which do not only  provide MIC inputs ( with internal preamp) but also a line output of these signals have taken the analog way. I use those outputs to attach a second recording unit for both redundancy and peak protection (recording at a lower amplification stage).
