Topic: Which interfaces use the same driver as Fireface 802?
I have a Fireface 802. I'd like to add a second interface that I can use at the same time in my DAW. I understand that, for that to happen, both interfaces need to use the same driver. But I haven't found good information on this.
Can anyone tell which RME interfaces use the same driver as the Fireface 802?
Thanks in advance!
RME Fireface 802, Windows 10, Intel Core i9 13900k (chipset Z790), 128GB RAM
Re: Which interfaces use the same driver as Fireface 802?
Hi
Go to the driver download section on the RME website. Select the driver for the Fireface 802 and your system and connection type (USB or FW), then you can see for what interfaces it is also working.
3 (edited by ramses 2023-02-18 14:24:29)
Hi Zarabozo.
Look to my comparison Excel, Line 26 "Driver" (also available as PDF).
For USB, there are only two drivers: USB and the later MADIface driver.
https://www.tonstudio-forum.de/blog/Ent … B-MADIfac/
Direct Link to Excel: https://www.tonstudio-forum.de/attachme … 9-19-xlsx/
So, the following interfaces are supported by the same USB driver: Babyface Pro FS, UC, UCX II, 802.
I would recommend, to take another 802 because then you have the following advantages
- for Option A: the same converters with the same converter latency not to get offsets in the DAW
- for Option B: two ADAT ports to be able to route up to 16ch between the two interfaces
  without having to route through the DAW with the full RTL over USB.
There are two possibilities to connect a 2nd audio interface
Option A) Two (or more) in parallel
     - Offers two possibilities for routing channels between the recording interfaces
          - routing all channels through DAW
          - routing up to 16ch between recording interfaces through ADAT (8ch per ADAT port in single speed)
     - Best option to use even more than 2 interfaces in parallel (more ADAT ports or WC for clock sync)
+-USB----802#1 (clock master)
PC           ADAT (clock synch via ADAT, alternatively over AES or WC)
+-USB----802#2 (clock slave)
Option B) 2nd unit behind ADAT
    - working mainly in one TM FX instance
    - any to any routing
    - the 2nd unit either in stand-alone mode or connected to USB to be able to operate it through a 2nd instance of TM FX
PC+---USB---802#1----ADAT1-----802#2 (either stand-alone mode)
    +---USB (optional)------------------+      (or additionally connected to USB to be able to manage it via 2nd TM FX instance)
To Option A) Two or more interfaces (best of same type) in parallel
According to the manuals, RME supports officially up to three devices (of the same type).
Even more should be possible if the computer allows it performance wise (number of channels).
They should be best of the same type so that the AD/DA converters have the same latency.
This is important if you have a setup, like in Option A, to not get track offsets because of different converter latencies.
You only need to take care of two things:
- to clock synch both devices by either WC (Word Clock) or by using a digital connection (via SPDIF, AES, ADAT)
- Windows: in the driver settings, you need to use the same ASIO buffersize. Otherwise, you get track offsets by this.
If you want to route audio channels from device #1 to device #2 you need to route either in the DAW (with the RTL through USB).
Or you have to use the 1 or 2 ADAT ports to route up to 8/16 channels between the two devices.
Alternatively, choose option B), then you have any to any routing in the TM FX instance of the main unit.
