Topic: [Solved] Fireface USB Settings Does Not Open (M1 Mac)
I typically just use the iPad with my Fireface UFX but I misplaced the iPad connection device, so I thought "I'll just hook it up to my mac to make a few small changes." I'm running an M1 MacOS 12.3.1. I installed the drivers, booted into recovery mode, etc. I think I did that all correctly. When I open TotalMix, nothing shows up. But if I turn off and turn on the Fireface while TotalMix is open, the mixer window magically pops up and the title bar says "RME TotalMix Fx: n.a. - disconnected". If I try to open Fireface USB Settings, the screen just flashes for a second, like an app is going to open, then nothing happens.
There are a lot of notes about using the Fireface USB drives with M1 macs and I think I followed those along properly, but clearly something isn't right. If I open Adobe Audition and map a channel to record, I can see that my mac 'knows' the Fireface and records the input. But I need to edit the submixes, etc in TotalMix.
Am I missing something obvious? Thanks!
