Topic: Madiface USB channels don't appear in DAW
Hi, I have the following issue:
I have 2 AD converters (24ch Euphonix AM713) that only have one MADI coaxial output each. The Madiface has one coaxial and one optical input, so one AM713 is going into the Madiface coaxial input, and one goes into a SSL optical/coaxial converter and then into the optical Madiface input.
Now the DAW only shows 64 input channels and 64 output channels. In totalmix I can see all 120 input channels and 64 output channels.
Can I somehow assign channels 65-89 to inputs 33-57? Meaning that whatever comes in through channel 65-89 actually also comes in through inputs 33-57? Or rather "rename" them so they all fit into the one 64 channel MADI lane?
I already tried a T-piece on one AD converter, but that failed.
I guess a second Madiface USB should be of help, but that would be overkill with 240 channels total.
Can someone help me? Thank you
HDSPe MADI FX / Euphonix AM713 converters
13700K CPU
16GB RAM
RTX4090
Re: Madiface USB channels don't appear in DAW
Loopback in TM FX enables you to have all 48 channels lined up in the lower channel area for recording. Route them to the first output channels one by one and activate loopback there...
So you really can have both optical & coax inputs enabled at the same time?
charlie post | postproductions audio | music rec. & live sound- acoustic music
https://www.rme-audio.de/madiface-usb.html
