Topic: TMFX as a simple active crossover?
If I have understood the manual for my UFX correctly, I could use TMFX to implement a simple active crossover by using the EQ facility; There is a Low Cut (high pass) option which works up to 500hz (which would be just high enough frequency for my set up).  There is also a variable High Cut (low pass) facility using Band 3.
1. Have I understood this correctly?
2. How do you actually implement the Band 3 High Cut?
Re: TMFX as a simple active crossover?
Can anyone help with my questions?
2. Just click the little graphic that would default to High Shelf... Next click is a High Cut filter and following that, a Peak filter.
