1 (edited by murrman 2023-04-25 12:17:39)
Topic: [Solved] Fireface UCX-ADAT 1/2 stopped working after update driver
After update - I powered UCX off and on and rebooted the computer and noticed my output stopped.
Totalmix is showing signal and volume at ADAT1/2 in the playback section,
but I have no sound / signal to my amp/speakers from that physical output.
I am wondering if something reset with the update?  Any ideas on settings to check??
Thought I would check here to see if i am missing something before I reported a bug.
2 (edited by waedi 2023-04-25 04:08:01)
Re: [Solved] Fireface UCX-ADAT 1/2 stopped working after update driver
murrman wrote:
Totalmix is showing signal and volume at ADAT3/4 in the playback section
Is this playback section the middle row of channels in Totalmix ?
The so called software playback channels ?
For listening this signal it has to be routed to a hardware output channel ( bottom row channels in Totalmix).
A screenshot of your totalmix would be helpful.
Which physical output? What's the UCX connected to?
4 (edited by murrman 2023-04-25 12:19:02)
Found the issue - the new driver reset the Fireface UCX settings to factory
It set the Output format for ADAT 1/2  to ADAT  instead of SPDIF
- when I set it back to SPDIF it worked!
