Topic: madifaceusb - Priority and Affinity reset to default after reboot
When I enter Task Manager in Windows 10 > click on the Details tab > scroll down to madifaceusb.exe > point to and right click on madifaceusb.exe, a pop-up window appears with a number of settings, of which two settings are relevant to me:
Set Priority
Set Affinity
Subsequently I change Priority from Normal to High
and when I click on Affinity, I disable All processors and enable CPU 2 only.
These settings prioritize the processing of the madifaceusb driver above all drivers and allocate the madifaceusb driver to be processed exclusively by the physical CPU 2.
These settings reduce latency and avoid hiccups.
However, when I reboot my Windows 10 systems, these settings are reset again to default and I have to manually set them again as mentioned above.
Interestingly when I apply the same settings to audiodg.exe and I reboot Windows 10, the settings are the same as set before the rebooting.
Is there any way to make the settings sticky i.e. permanent?
