Topic: Routing wet signal
Is this easy? Most probably I am missing something basic.
I am recording in Analog Input 3 which goes to DAW. It comes back "post FX" as USB IN in TotalMIx and is routed to Main 1/2.
Seperately I want to route that instrument to Analog Output 3. But there It arrives as dry signal, it did not go through the DAW.
How can I get the wet signal to that separate output?
Thanks for support.
2 (edited by waedi 2023-06-03 19:34:20)
Re: Routing wet signal
In Totalmix the wet signal coming from a DAW is visible in the middle row channels Software Playback Channels. Pull up the fader.
The top row channels Hardware Input Channels are the dry signals from your instrument. Pull those faders down.
