Topic: Ground loop and buzzing with hdmi display
I seem to be have run into a ground loop issue when connecting a monitor display via hdmi.
The setup is as follows:
M-32 AD > Digiface USB > Fireface 400
The Fireface acts as the outputs and the M-32 AD as inputs.
I'm using a Macbook Pro with 2 thunderbolt ports. In one of the thunderbolt port I connect the fireface 400. In the other port I have a Satechi hub with the Digiface USB connected and two other usb ports connected for midi and mouse/keyboard.
I use some of the outputs of the Fireface 400 (3 outputs to be exact) for sending audio via ableton to effects pedals. And then back in via the M-32 AD.
This situation above works fine until I introduce a monitor display connected via a hdmi cable on the Satechti hub.
The monitor causes a ground loop with the inputs of the effects pedals which only goes away when I disconnect the macbook charger or remove the hdmi cable.
Is there any way to fix this?
Thanks in advance,
Sinan
