Topic: Fireface ucx ii with Arturia Audiofuse Studio ADAT??!
Hey !
Do you know if i can just connect the two interfaces through ADAT for more inputs? Do i need anything else other than the audio optical cable?
Thanks a lot in advance !
y
Re: Fireface ucx ii with Arturia Audiofuse Studio ADAT??!
ADAT will work fine...
Hey !
So i don't seem to make it work. I am connecting ADAT in to the RME and ADAT out from the ARTURIA. I am not receiving any Audio, anything else i need to do?
Best
y
The Audiofuse probably needs configuration to work this way, that is not something we can help with.
5
If the clocking is not correctly done then any ADAT input signal will be muted. Check the Settings dialog, read the manual's chapters about clock setup...
Hey again ! I have picked up my audient asp 880 from the studio and connected it via ADAT to the RME and still it doesn't work.
I am connecting input RME to output Audient, master or slave i am not getting any signal in total mix...I am using a normal optical cable that i used all my life, am i missing anything here?
Thanks in advance !
y
I tried to change the cable, i tried all the clock settings that are possible, i am not getting any connection between the two. In the "Fireface USB settings" it is not showing me any connection in the input status.
To be honest, now i remembered why i sold my rme years ago. It is always never easy with the RMEs..
So frustrating...
I've used several different 8 and 2 channel AD/DA converters with both my Babyface Pro Fs and UCXII and had no issues once the settings were correctly configured. I don't know the Arturia you're trying to use but I think it's another interface, not standalone ADAT converter? I'm wondering if that is part of the problem? Is the Arturia ASIO?
you haven't mentioned how you're routing the incoming ADAT signals in Totalmix. I understand you're not hearing anything but are you seeing any levels on the UCXII display? how long have you had the UCXII?
sorry you're having problems and are frustrated. hopefully someone more experienced with what you're trying to do will respond soon smile
Thanks in advance !
y
Hello!
Can you post a screenshot of your "FireFace Usb Settings" and TMFX?
10 (edited by waedi 2023-07-29 06:54:12)
May be a Loopback test can show if the Audiofuse is sending Adat signal ?
Connect an Adat cable from output to input and see if a send signal arrives in the input ?
Hey !
Thanks for your help, i gave up the trying to connect the Arturia and now i am only trying to connect it with the Audit 880 via ADAT. So basically i am going IN RME and out on Audient (it has only out for sure). Still no sign of connection in RME Fireface USB settings.
As i said, no sign of connection whatsoever, even if i change the clock setting on the Audient. Here you go:
https://www.dropbox.com/scl/fi/ann8v3ds1fgk7hq1jvjvv/Screenshot-2023-07-31-at-00.49.22.png?rlkey=utnqge8cpclng6lzydwv0y7t1&dl=1
Thanks in advance !
y
Hello!
A this point, i start to think it is a hardware problem, will try to buy another cable tomorrow (tried two already but who knows) and then it is either the Audient connection got broken with moving or the RME came with a faulty ADAT connection. I really don't know...
14 (edited by waedi 2023-07-31 00:03:19)
Did you try clock-setting external adat optical in the RME settings (while the clock in the Audiofuse is set to internal) ?
15
Takes 10 seconds to find out. Plug ADAT out to ADAT in (cable loopback on the UCX II ) and see if the signal is received and audio coming in.
Yes, Still nothing is changing in the Fireface USB Settings
I just tried, going out of the RME into IN again, nothing changes, no signal on the ADAT channel and no sync or anything in the input status of the "Fireface USB Settings". Where should i see a change actually?
Here is another screenshot (i am sending audio from my synth on Channel 6 just to see)
https://www.dropbox.com/scl/fi/iohaou10rexta7nprxtho/Screenshot-2023-07-31-at-11.54.09.png?rlkey=vi23ly8phzc4h3p6awownyubk&dl=1
I'm gonna go and buy a new ADAT cable, even though i have tried two of mine, just to clear this out finally.
Do you see a red light on the ADAT OUT plug and when you plug in the TOSLINK cable do you see the red light on the other end coming out?
I unplugged the cable that is going to the "IN" and yes i see red-light coming from it. Kept the side that is going to the "Out". What does that mean now?
This means that the optical fiber inside the cable is not broken (the cable is OK) and that 99% the reason for the issue lies somewhere else.
