Topic: RME UFX II Mac Ventura
Hi, I face audio issues at random frequency.
Is that a driver issue?
Here from the console log
standard 11:49:33.736155+0200 GigPerformer4 HALC_ProxyIOContext.cpp:1186 HALC_ProxyIOContext::IOWorkLoop: skipping cycle due to overload
fehler 11:49:33.743974+0200 coreaudiod 318143 HALS_IOEngine2.cpp:3683 Detected possible coloring mixer glitch on RMEUSBDevice-196-23794757: buffer time: 307072936 actual time: 307072488 safety violation: -224 with 2 running contexts
fehler 11:49:33.744616+0200 coreaudiod 436535 HALS_IOEngine2.cpp:3683 Detected possible coloring mixer glitch on RMEUSBDevice-196-23794757: buffer time: 307072872 actual time: 307072663 safety violation: -91 with 2 running contexts
standard 11:49:33.747513+0200 coreaudiod CAReportingClient.mm:537 Sending message { message="{
"HAL_client_IO_duration" = 4975287;
HostApplicationDisplayID = "com.deskew.gigperformer4";
cause = "PageFaultsOffIOThread,ClientHALIODurationExceededBudget";
deadline = 307072296;
"input_device_source_list" = Unknown;
"input_device_transport_list" = USB;
"input_device_uid_list" = RMEUSBDevi57;
"io_buffer_size" = 192;
"io_cycle" = 3702;
"io_cycle_budget" = 4520788;
"io_page_faults" = 0;
"is_prewarming" = 0;
"is_recovering" = 0;
"issue_type" = overload;
lateness = 28;
"other_active_clients" = "[ { HostApplicationDisplayID_other_client: com.ableton.live, sample_rate_other_client: 48000.478027, io_buffer_size_other_client: 256 }, { HostApplicationDisplayID_other_client: com.deskew.gigperformer4, sample_rate_other_client: 48000.478027, io_buffer_size_other_client: 192 } ]";
"other_page_faults" = 32;
"output_device_source_list" = Unknown;
"output_device_transport_list" = USB;
"output_device_ui", reporters="<decode: missing data>" }
standard 11:49:53.203979+0200 GigPerformer4 HALC_ProxyIOContext.cpp:1186 HALC_ProxyIOContext::IOWorkLoop: skipping cycle due to overload
fehler 11:49:53.209994+0200 coreaudiod 318143 HALS_IOEngine2.cpp:3683 Detected possible coloring mixer glitch on RMEUSBDevice-196-23794757: buffer time: 308007336 actual time: 308006952 safety violation: -168 with 2 running contexts
fehler 11:49:53.211586+0200 coreaudiod 436535 HALS_IOEngine2.cpp:3683 Detected possible coloring mixer glitch on RMEUSBDevice-196-23794757: buffer time: 308007272 actual time: 308007072 safety violation: -125 with 2 running contexts
standard 11:49:53.214395+0200 coreaudiod CAReportingClient.mm:537 Sending message { message="{
"HAL_client_IO_duration" = 5175096;
deadline = 308006760;
"io_cycle" = 4865;
"io_cycle_budget" = 4520782;
lateness = 45;
