Topic: Fireface UC does not work on M1 Macbook Pro
The current state:
The installation completes fine, but after restarting I cannot open the fireface settings (it closes right after opening) nor is the interface recognized anywhere on macOS. It is connected via a USB-C Type adapter, that works fine on my windows machine.
MacOS Monterey 12.6.8
Driver Version:
DK408_2
Fireface UC USB:
Hardware Revision: 127
(Updated for this specifically and the update works fine with Windows)
I have tried everything I could find on the forum so far:
Removing the drivers entirely before reinstallation on MacOS, Using the trigger-panic-medic (the System Security settings seemed fine after the installation, I was always asked to allow RME and Fireface Settings).
I don't know what else to do. So maybe someone has a tip
Re: Fireface UC does not work on M1 Macbook Pro
Did you switch the unit back to Apple firmware mode after using it on Windows?
https://youtu.be/PS5-_kpizTE
Thank you very much, this worked! I never noticed this switch until now and I was so sure it was a driver issue, but it wasn't.
