Topic: ADI-2 Digital pass-through, how to turn it on?
As my ADI-2 is currently serving as a DA only, I had a quick read of the manual and found this:
"The button INPUT LEVEL offers a fourth state (LEDs off), digital pass-through mode with analog monitoring (DA-converter). In this mode the AD-converter is not used. The level meters show the audio level of the digital input signal."
I am, however, unable to turn this feature on, am I missing something obvious? The input button only cycles between the three levels, not a fourth "all leds off" setting.
Thanks,
j,
HDSPe AES/Babyface/Adi-2
Re: ADI-2 Digital pass-through, how to turn it on?
You have an older unit without this feature. The manual that you read (most probably from our website) describes a newer unit (after 2006).
Ah. That explains it.
Thanks,
j,
