oli77sch wrote:TomVY wrote:So if the Babyface running from bus power means some quality is compromised, I would lean towards the ucx II.
No audio quality compromise at all. BBFproFS is excellent.
Yep.
The thing is, that the USB2 bus has only a certain power that it can deliver.
So you can only put a certain amount of circuits ("energy consumers") into such a device.
Or you can only implement headphone outputs with a certain more limited power compared to recording interfaces with a power supply. For headphones with normal impedance the BBF Pro has sufficient power.
What has been implemented into the BBF Pro FS are high quality components and the sound is not degraded in any way.
But you can not pack more into the device, because it has an optional PSU, because it needs to run reliably on USB2 and then you can implement what can be powered by USB2. But it is indeed nice, that you can connect an optional PSU just for the case that your laptop doesn't deliver USB power well, to be able to exclude any potential problem in that area.
There are only certain things for which USB does not deliver enough power, it has been mentioned already in this thread.
For example:
- no FX chip
- weaker headphone outputs, still well but weaker compared to the other RME recording interfaces like UCX II, UFX II, ...
- not so much gain on the Mic inputs, but still well compared to most devices of the competition
I regard it as an advantage to have Mic inputs in the device. If you want to take it with you, then you do not need to carry the external preamps necessarily as well and it is also good as reference, how transparent mic inputs sound compared to others which might have some color.
I wouldn't recommend buying too small, your demand might increase over time and buying an RME interface is not like with consumer devices, that you buy it for 3-5 years, you have such a long driver support, that it is much likely that you will have it much much longer, see how long Fireface 400 and 800 are being sold on used market.
