Topic: Best way to add more analog I/O to my setup
Hi all,
I'm a happy UCX user who has a hobbyist home studio. I now own more synths than I have analog I/O for so I was looking at the best way to add more analog I/O to my setup. I don't need to record all of these synths at once, but it is a bit annoying having to plug and unplug instruments as I use them.
Here are some of my ideas, from least cost to most:
1) Get a patch bay, cost would be small but possibly the cheapest solution. Still have to deal with plugging and unplugging.
2) Get an ADAT expansion. I see Ferrofish recommended to RME users, but it seems the smallest they have supports 16 I/O. The most my UCX could support is 8. Not sure what the other options are out there.
3) Upgrade to a UCX II. I could keep my original UCX. It's not clear to me if it would be better to use both interfaces connected to USB individually or to have the older UCX serve as an ADAT expansion for the UCX II. My understanding is that since they are of the same product family, TotalMix will allow me to use both units in Windows. I do like the idea of having the DC coupled outputs to use with my modular synth setup.
An aside, I would like to rack mount these if possible, but my dealer has the Unirack (Silver) and the Unirack II (Black). The latter mentions fairly old interfaces so I'm thinking the silver one is newer one I would need? Can any owners comment on how clean this solution looks in a rack? With the UCX vents on the side of the unit, is there an issue with heat going into the neighboring UCX II?
4) Upgrade to a UFX III. I have to be honest this does feel overkill for my needs. I would still get the DC coupled outputs of the UCX II which is why I'm looking at this model vs the UFX II. It does feel like the most futureproof solution. However I just recently solved some USB ground noise issues with the Hifime v2 USB isolator. MC have you tried that isolator with the UFX III? I'm concerned it won't support USB 3.0 speeds and if that is the case, I would need to consider this option will actually be an additional $400+ USD more to purchase Intona's USB 3.0 isolator.
2 (edited by ramses 2023-10-11 05:19:00)
Re: Best way to add more analog I/O to my setup
to 3)
> [ UCX and UCX II  ]
It's not something like "product family" which is the relevant part here.
The point is that an application for audio (DAW or whatever) can only load one sound driver at a time.
So, to be able to use two devices, they need to use the same ASIO driver under Windows.
This is the case with the UCX and UCX II as they are using the same USB driver.
The disadvantage of such a setup with multiple recording interface is, that you can't route across the interfaces.
It is not possible to route HW inputs and SW playbacks of interface#1 to HW outputs of interface #2 with near-zero latency.
A workaround is to use e.g., ADAT to route up to 8 ch in single speed between the two different interfaces, but this spoils your ADAT ports and is also from operational perspective not so good to operate. You have to work and route between two TM FX instances. You can of course route through the DAW … but then you have always the full round trip latency in the communication flow. Depending on the ASIO buffer size that you have to use in your project this can add much latency.
A better solution is a setup with only one recording interface and one TM FX instance where you can route any HW input and SW playback channel to any HW output.
But to also get DC coupled outputs you would need to get the new UFX III, as there are not so many RME interfaces which have this option for all analog channels (not only headphones), currently only UCX II, 802 FS and UFX III.
Details see my Excel comparison sheet here: https://forum.rme-audio.de/viewtopic.php?id=35156
As I am not sure what your top priority is, I give you below a few suggestions, how you could achieve more analog channels by using only one recording interface, so that routing through DAW can be excluded completely.
Not sure whether PCIe can be used for your setup, but the RayDAT (a pure digital card) offers 4x ADAT I/O and gives you much flexibility in terms of different types of I/O. In this setup no DC coupled outputs possible as also the Pulse 16 doesn't offer those.
The new UFX III would offer DC coupled outputs to you. But in terms of more analog channels you would need to add a converter like the Ferrofish Pulse 16 MX, to be able to connect it through MADI. Because MADI offers 64ch in single and 32ch in double speed, then you can use this setup for single and double speed (44.1/48 and 88.2/96 kHz).
Note: I left out the 802 FS below, for two reasons, not 100% whether you see it the same way:
- the two ADAT outputs would limit the 16ch AD/DA converter (Pulse 16) to be operated in single speed or you would loose 50% of ports in double speed
- the mic channels are not digitally controlled (I personally do not like this), so you can't store a complete setup including mic gain, phantom power, ... in snapshots
Note 2: I left out the UFX II for two reasons
- has no DC coupled outputs
- has only 2 ADAT ports, this limits you to single speed, as mentioned above
1) RayDAT + Ferro Pulse 16 = €599+€999 = €1598
PC---USB---ARC USB (optional)
| PCIe
RayDAT<-----ADAT 1-4------->Ferro
or
2) RayDAT + Ferro Pulse 16 + ADI-2 Pro FS R BE =  €599+€999+€1699 = €3297
| PCIe
         \AES
          \-------------------------->ADI-2 Pro-------monitor/phones
or
3.1) HDSPe MADI FX + Ferro Pulse 16MX                          = €1439+€1249 = €2688
3.2) HDSPe MADI FX + Ferro Pulse 16MX + ADI-2 Pro FS R BE = €1439+€1249+€1699 = €4387
| PCIe
HDSPe MADI FX-----MADI1--->Ferro
         \AES
          \-------------------------->ADI-2 Pro (optional 3.2)
or
4) UFX III  + Ferro Pulse 16MX = €2689+€1249 = €3938
| USB3
UFX III-----------MADI----------Ferro
If you require DC coupled outputs, I think this is not offered by UFX II yet.
And with UFX II (with only 2x ADAT I/O) you would be limited to single speed when getting Pulse 16.
Therefore, I would recommend as of now to get UFX III and Pulse 16 MX via MADI (option 4).
You can sell the UCX to get some good money to cross finance.
The UFX III has the same converter as the former ADI-2 Pro FS.
If single speed and the number of channels is enough maybe this option:
5) UFX III  + old UCX in stand-alone  = €2689
         PC------------USB---------ARC USB (optional)
USB3 |  | USB2
         |  +--------------------------------------------+ (to operate the UCX and for firmware upgrades)
       UFX III<----------------ADAT--------------->UCX
                      route up to 8ch from/to UCX
This solution is limited to single speed otherwise you would in double speed only have 4ch via ADAT
Replace UCX with Pulse 16 MX later and connect through MADI.
This way you can split the investment.
Thanks ramses, you've given me a lot to think about!
I will say that I do enjoy the class compliant mode on my UCX and occasionally use it with my iPad. I also sometimes use a MacBook, so I think the pcie solutions won't be an option I'll consider.
Otherwise it seems like running a UCX and UCX II wasn't going to be quite as smooth of an experience as I was hoping it would be, so it seems all signs point to UFX III being the upgrade that makes the most sense.
I saw the 802 FS and thought that would check all of the boxes for me. I don't need some of the UFX III features. However, I am also in agreement I prefer the digital control and being able to recall everything in snapshots is something I'm already used to. So I don't feel I could compromise on that.
The UFX II could be an option if I decide to forgo DC coupled outputs, but at least in the US the price difference is $400 so it doesn't seem to be a huge savings in that regard. I actually like your prices compared to what I see in the states haha, a UFX III is $3200 USD before tax.
