Topic: How to connect the ADI-2 DAC fs to a Playstation 5?
yeah tried looking and cant figure this one out
PS5 doesnt have optical
I can connect PS5 to TV via HDMI
Then connect TV to Receiver via Phono cables
This is where i get stuck
I connect phono cables to the ADI-2 and then switch it on but no sound comes into the headphones
I'm doing somthing wrong
thnx
2 (edited by waedi 2023-10-21 13:27:09)
Re: How to connect the ADI-2 DAC fs to a Playstation 5?
This is the wrong attempt, the DAC has no analog inputs.
You have to use a converterbox hdmi to spdif
Something like this :
https://www.digitec.ch/de/s1/product/de … er-2485634
3
AFAIR there are also converter boxes USB 1 (a PS 5 limitation) to SPDIF which would also work.
Indeed at Amazon :
https://www.amazon.com/-/de/dp/B0BV7CBX … uage=en_US
ok so this device, it connects to ps5 vias usb?  then how does it then connect to the ADI-2?
looking at the pictures its not clear unless im missing somthing? or does it then go in the optical port?
also how does this device gets power, unless its usb power?
In the description : ...no power supply
Therefor USB-bus-power
And yes from this converter via optical toslink cable to the adi-2 optical input.
Stereo-signal only.
aah ok, thanks, the link you have given is USA Amazon
I'm based in the UK, so UK Amazon
so trying to find somting similar in the UK
will these work:
https://www.amazon.co.uk/XMSJSIY-Digita … mp;sr=8-12
https://www.amazon.co.uk/HDMI-Audio-Ext … 5a65d91d81
https://www.amazon.co.uk/XMSJSIY-Digita … B0BNMRYMCT
The one from my link is explicit dedicated to Playstation 5 and 4
Link 1 and 3 from you looking good but I can't say.
Link 2 will work but it says the optical audio out will provide surround 5.1, not sure how this will work for the ADI-2...
I would do the risk and try one of the USB units. I mean your risk.
