1 (edited by arkdzo 2023-11-03 15:02:34)
Topic: [Solved] NO sound in Cubase 13 Pro with RME Babyface PRO
Hello! I used Ableton Live and everything worked fine with my RME Babyface PRO. I installed a new Cubase 13 PRO (13.0.10) and I don't hear any sound. Can you help me?
My settings:
Fireface USB Settings: https://ibb.co/Zxy9N9p
Cubase Studio Setup Settings https://ibb.co/tznDxKB
TotalMix FX Settings https://ibb.co/7XF2mTR
I HAVE FIXED THE PROBLEM
Steps:
1. Open Studio - Audio Connections
2. Go to the Control Room tab
3. Select Analog1 (left), Analog2 (right)
4. Open CR tab on the right panel
5. Press the Main stereo button to turn on the Control Room
2 (edited by waedi 2023-11-03 11:43:44)
Re: [Solved] NO sound in Cubase 13 Pro with RME Babyface PRO
The link of the Cubase setup has a mistake in it the m is wrong it should be https not hmttps
All three images looking fine if you play a music in Cubase is in Totalmix nothing showing up ?
Edit : In the Cubase control room you have selected output channels 1/2 for master bus ?
fixed the links
4 (edited by arkdzo 2023-11-03 11:54:16)
If I play a music in Cubase in Totalmix nothing showing up, yes
I tried to set analog 3,4 and ADAT 3,4 but it doesn't help me. What do I need to choose here?
Cubase Control Room: https://ibb.co/qjDdHxQ
Windows Audio: https://ibb.co/XbfHkvX
I have fixed the problem!
https://ibb.co/PxMFkL8
You where coming from Ableton, that was the culprit.
Cubase is the mother DAW, good you learn it !
