Kubrak wrote:Also, if latency is the most important, Digiface USB probably adds few samples lag to connected interface.
Or am I wrong? How many samples does it take to transport ADAT signal from input to output (including all the matrix computation). It must be at least one sample, if things go very fast. It cannot be, IMHO, less than one sample.
I remember from an old thread where MC answered that you can ignore that. Yes maybe 1 sample, who cares.
Assumed: with the UFX II he might save up to ~1+ ms converter latency depending on what other external AD and DA converter the unit uses and how old AD and DA converter are.
But this might stay unclear because other vendors are not that detailed like RME to document converter latencies in the manual.
Compare e.g. converter latency of if different units over time (AD/DA at single speed, 44.1 kHz, in samples)
- UC (from 2009) 43/28 samples
- UCX (from 2012) 14 / 7 samples
- UFX II (1st HW from 2017, seems to get an update now) 12 / 7 samples
- UCX II (from 2021) 5 / 6 samples
- UFX III (from 2023) 5 / 6 samples
In my Excel line 33 "Converter latency in samples @44.1kHz AD/DA"
For gettin the value in ms, then check the RME manuals, search for chapter "Latency and Monitoring"
But finally, in terms of RTL (round trip latency, A/D, transport to/from PC, D/A conversion) you are getting more latency anyway by the transport over USB/FW, depending on
- Windows: ASIO buffer size
- Apple: the buffer settings in the application
The converter latency only adds a little bit.
For me converter latency is interesting, and I want to keep it as low as possible, as I am using my unit as a parallel effect loop for the guitar amps. So I do not want to lose time between hitting the strings on the guitar and getting the signal finally to the power amp section of the guitar amp.
