Topic: is the Fireface UCX II works in High sierra
Hello, I'm currently using a Fireface 800 in firewire on a MacPro 5.1 running on High Sierra 10.13.6
I would like to upgrade to a Fireface UCX II but i can find if it's working on that particular MacOS.
Does anyone have tried this set up before?
I found on this page that there is a driver working from 10.12 to 10.15
https://www.rme-audio.de/fireface-ucx-ii.html
but I also seen people saying that the UCX II require MacOS 11 Big Sur or Higher.
Can someone reassure me that it works?
Thank you
2 (edited by waedi 2023-12-07 21:33:39)
Re: is the Fireface UCX II works in High sierra
No problem, the UCX ll will work on your computer.
High-Sierra is MacOS version 10.13
The Driver for this is that one : the kernel extension driver 3222B2.
from this page : https://rme-audio.de/fireface-ucx-ii.html
Go to : Drivers - USB - Mac OS X
There are newer drivers for newer MacOS versions, because Apple has changed a lot in the system architecture in the last years.
The drivers had to be modified to fit.
