Topic: Using Fireface UFX II/III as surround monitor controller with ARC USB
Hello people,
Just registered although I'm a satisfied RME user for a very long time.
After doing some searching on these forums I couldn't find any relevant questions so I'm starting a new topic.
I have this challenge and I'm looking for some feedback about the following.
My current setup is PC with MADI FX connected (MADI) to ADI-648 and ADAT1+2 are connected (ADAT) to a Yamaha 01v96i that acts as a routing matrix (converting 7.1 to 7.2) that connects (ADAT) to a Prism Orpheus AD/DA converter (with SPL Volume8 as passive controller) and a Kii audio remote (SPDIF coax). Yes, it's quite a mess but it organically grew that way.
My speaker setup are 2x Kii Audio three monitors connected to a Kii remote control, 2 active subwoofers Scanspeak Maxima, 5 passive Scanspeak A4 monitors using Quad 303 amps. So 2 digital inputs (spdif coax/optical) and 7 analog inputs for a 7.2 speaker setup in short.
My wish is to eliminate some of those shackles in the chain. The Orpheus only can be configured with firewire400 and in my 2nd PC I have a PCIe firewire card for just that purpose. So I thought I could use either a Fireface UFX II or III as a monitor controller with the ARC USB remote to replace the 01v96i and Orpheus. Since PC cannot use aggregate devices you need a solution that allows for the ASIO for all channels at the same time. I don't think you can mix and match ASIO from MADI FX and UFX at the same time. If I'm wrong about that I stand corrected.
The new setup would be Madi FX -> ADI-648 -> UFX II or III (with ARC USB) -> Kii remote, Maxima and Quad amps.
I wish I could use the MADI to UFX directly but all my MADI ins/outs are used already by an Antelope Orion32+ Gen3 and Ferrofish A32 Pro. Why do I have that much I/O? Because all my gear is directly connected dedicated to be used as external devices in my DAW.
Alternative setup would be MADI FX(2nd card) UFXIII (with ARC USB) -> Kii remote, Maxima and Quad amps. I do have a spare PCIe slot. Albeit this solution would be more costly. Also when I read the MADI FX manual it's stated that multiple MADI FX in the same system is possible but how this actually works is not further explained.
My question is basically can I use in this setting a Fireface UFX II or III as a stand-alone 7.2 surround monitor controller with the ARC USB as volume control?
Of course there is the need for using the USB connection for configuring the UFX Totalmix settings and then enable the ARC USB to control all I need. Can I use Totalmix for the Madi FX next to the Totalmix for the UFX?
Are there any other things I may have overlooked? I tried to be concise as possible. If you have any questions I'll be happy to answer them.
If you reached this far in my long topic and you are willing to give some feedback, thank you for you interest.
