Topic: Digiface Dante - Intel Macbook Sonoma 14.1.2 - Netifc invisible?
The network adapter doesn't show up in the Network Settings. How does it work? What if I want to set a static ip?
I've tried installing and removing it multiple times. Even updated from Ventura to Sonoma. Still nothing.
The dante part works fine, Audio works. I can even use Dante Controller using Bridge9999. Do I manage this adapter in Dante Controller to set an ip? There are no settings in Network?
Thanks.
Re: Digiface Dante - Intel Macbook Sonoma 14.1.2 - Netifc invisible?
You can change it to static via a simple terminal command.
See here:
https://forum.rme-audio.de/viewtopic.ph … 57#p191757
3 (edited by Canadiansoundguy 2023-12-14 17:07:54)
See here:
That doesn't really help. I thought it would work as a normal network adapter like it does in Windows. It doesn't show up as a network adapter so it doesnt show up in software like LA Network Manager, Nexo's Amp controller software NeMo, and others.
Is there no way to have it show up as a network adapter? Or do I just have to use a usb ethernet adapter and disable netifc?
