Topic: A strange signal appears on the analog input - ADI 2 PRO FS R BE
Hello!
I usually send a DSD signal to the PRO FS R. (From HQPLAYER/ROON or Audirvana Studio) A strange signal appears on the analog input when the conversion type of the line input is set to DSD. It doesn't matter whether the Direct DSD mode is on or not. It's strange that it doesn't appear on the "summary" screen. If I switch the line input conversion to PCM, that signal appears on the summary screen.
There is currently nothing connected to the analog inputs!
A Jack/RCA converter is connected to the line outputs, which goes to an amplifier, and the signal also goes to a headphone amplifier via an XLR cable.
When sending a PCM signal, e.g. from the Amazon Music application, there is no strange signal on the analog input. Mac OS: Sonoma 14.1.2 (23B92).
I made a video, so maybe it will be more understandable. Could this be a bug in the firmware?
https://youtu.be/ObMLBKzQA2A?si=72QOu9-whXObOgPL
I updated to the latest firmware version yesterday.
Thanks for your help!
