Topic: ADI-2/4 Pro SE as hardware I/O for measurements
I wish to use the ADI-2/4 as an audio analyzer. I have read page 84 of the manual and note the following remarks.
Tips for optimal measurement results
Improve the signal-to-noise ratio (and thus THD+N) at the analog input by mono operation
To do this, simultaneously place the source on both inputs using a split cable and activate M/S processing in the analog input. The left channel now has an SNR of 124 dB (AES17) instead of 121 dB at unchanged level.
Improve signal-to-noise ratio (and thus THD+N) at the analog output by mono operation
To do this, use a split cable to connect both outputs, which must output the same signal, to one cable. This 'short circuit' uses internal resistors of the ADI to improve the SNR by 2.5 dB.
Pardon my ignorance but I hope to know:
What is the best wiring approach in a loopback setting (i.e., ADI-2/4 analog outputs -> ADI-2/4 analog inputs)?
What is the best wiring approach in a standalone setting (i.e., Other DAC analog outputs -> ADI-2/4/ analog inputs)?
Your help is much appreciated. Thanks in advance.
