Topic: Zoom audio routing
I use an Adi-2 Pro FS BE for teaching via Zoom. I sometimes struggle to play/demonstrate something as I can't hear myself properly when using headphones. Is there a way to route the sound from my mic to my headphones whilst also sending the same audio to Zoom?
Re: Zoom audio routing
May be enabling Hi-power could help you out ?
Hi-Power
OFF, ON. Default: OFF. Reference level for 0 dBFS is +7
dBu at the output. With Hi-Power on reference level is 15 dB
higher, +22 dBu.
Would Hi-Power route the audio to my headphones? There is currently no signal going into the phones from the mic when Zoom is active. The audio I hear is from the other participant in the call. It seems Zoom is routing their audio to my phones but I don't hear any of my own audio. To be honest I'm not sure whether this is a limitation of Zoom's audio settings or whether I can get around it with some fancy solution using the Adi 2.
Zoom is sending and receiving on channels 1/2 fix.
In the menu in the ADI-2 you have to select the source for headphones.
Select USB 1/2
5 (edited by KaiS 2024-01-23 17:35:38)
ADI-2 has no provision for mixing multiple sources, like the mic and the audio from Zoom.
This has to happen inside the host, e.g. Zoom, or in the Windows Mixer.
