Topic: Easy Access to EQ
I have the UCX II
I have two layouts that I would like to easily switch between. One has no eqs and the other has separate eq on each output channel. Otherwise the two layout are the same
I realize that the snapshot does not store eq settings but the Workspace does
I know I could load a file but I would like an easy way to switch between the workspaces - If possible with a single button or even better with a physical button on the unit.
Is there an easy way to do this or do I just have to load different workspaces
Re: Easy Access to EQ
Try to use quick workspace select, you can toggle between the first 10 slots by using ALT-1 .. ALT-0.
