Topic: Weird Gain Crosstalk between Mic Preamps
So I was testing an XY Stereo Setup on my RME Fireface UFX II and wasn't able to match the mics output with the same gain value on both channels (11 and 12 in my case). Channel 11 always puts out a hotter signal than Channel 12. I randomly found ot that the Gain Knob of Channel 10 was controlling the Gain for Channel 12 too. Setting it to maximum Gain gave me the missing 12-13 dB on Channel 12.
https://i.ibb.co/qR49KDh/RME-Gain.jpg
Any Idea what's going on here?!
2 (edited by oli77sch 2024-02-11 21:57:18)
Re: Weird Gain Crosstalk between Mic Preamps
Hi
Have you ruled out all other possibilities that could be causing the issue? Are the mics ok for sure? The cables? How is it on the two other mic inputs of the UFX II? Also, to compare two mic input levels I would suggest not to use an XY array but mounting them together as close as possible in parallel to make sure they pick up the (almost) exact same signal.
3 (edited by waedi 2024-02-11 02:54:49)
What version of Totalmix is this ? Try to update
Also firmware should be checked to be up-to-date.
I am on latest firmware and TM FX and cannot reproduce this issue.
If you pull up the gain fully on an input with no microphone connected, you'll get a little noise. That is shown on the Mic 10 input of your right picture. That is totally normal, I think.
12 Mic, M1610 pro, Micstasy
MacBookPro M1
Logic Pro X
That's not what the OP described.
I tested again and the cables and mics are fine. Tested them with my Zoom F6 and it works just how it should. But I noticed that it's not just Channel 10 controlling Ch12 but also Ch9 controlling Ch11 - I just didn't notice because my SMB7 is always connected to Ch9. See picture below.
Im running TotalMix 1.90 beta 1 - I might try going back to the latest official release.
https://i.ibb.co/Bt8J4hJ/RME-Gain2.jpg
oli77sch wrote:
Hi
8 (edited by oli77sch 2024-02-12 17:14:00)
Is there loopback activated somewhere on the analog outputs corresponding to the mic inputs (so analog out 9 - 12)?
And another question. Is what you see in Totalmix corresponding to what you actually hear when monitoring all this?
9
Perform a Total Reset in TM FX. Also current version is 1.93. Your firmware therefore might be also outdated.
no loopbacks or anything. everything is clean in the signal chain. And what I see is a direct representation of what I hear. Once I turn up the Gain for my SMB7 on Ch9 the left signal of my XY (Ch11) get's boosted by a lot too.
I did a Total Reset, updated to 1.93 and updated the UFXII Firmware. No changes hmm
Did you swap the microphones already?
Does the issue move with the mics, that you get more output with one?
As stated before, mics and cables are not the problem. I can also produce this issue just visually with no mics connected.
13 (edited by ramses 2024-02-13 10:58:55)
I recommended that to perform tests properly to be on the safe side to get valid test results.
An open analogue input might react other than expected.
I understand your point that you expect all open mic inputs to behave similarly at the same gain, but I would still recommend performing such a test so that the inputs are used according to their specification.
That's why I would re-plug the mics, just to be on the safe side here.
This does not lead to any speculation as to whether it might have something to do with the open analog inputs.
14
This thread leads nowhere until touringen starts to use the UFX II for serious testing, and it is not hard to do. Connect the analog outputs to the mic inputs, play back a test tone on all 4 outputs at a very low level (attenuated by TM or the player) so that the mic gain can be fully cranked up without overload. Then compare the levels you get in the input. This is the only way to have valid results for gain mismatches.
An even simple version uses only one output and replugging the inputs to check for differences.
Open inputs suffer from crosstalk at high gains, that is normal and not an issue.
15 (edited by oli77sch 2024-02-13 13:20:38)
Nor this statement nor what ramses writes explains this:
I do take this serious - sorry if I did not communicate that clearly. I did test with connected inputs first and then with open inputs because the issue remained unchanged regardless of outside influences.
Now I did another test with a feedback loop as requested. It still remains the same.
440Hz Test Tone at -10dB. Outputs 9-12 (Phones) to Inputs 9-12.
The Threshold for this to happen seems to be around 64dB of Gain. Anything around or under 63dB Gain doesn't influence the other channel.
https://i.ibb.co/W26tGL9/RME-Gain3.jpg
What's the exact firmware and driver version?
Can you reproduce this with the interface connected to another computer?
I updated everything to the latest version today. Total Mix 1.93, FW 23 and Driver 0.9833.
I don't have another Computer to test this with.
19 (edited by oli77sch 2024-02-13 20:43:15)
touringen, in your screenshots from post 16 I can see the input signal strength on channel 10 remains the same regardless of the three gain settings (63,64,75 dB). So as soon it’s over 63dB, not the signal of this channel is increased, but the one of channel 12.
Really weird!
EDIT: you have talkback activated on the phones outputs. What source do you have set for the talkback and what happens when you disable it?
Really weird!
Exactly! Good catch! I was so focused on Ch11/12 that I didn't even notice that. It's the exact same threshold for that behavior. At around 64dB of Gain the gainstaging of Ch9 "takes over" to control Ch 11 and vice versa Ch10 controlling Ch12.
I have none defined as a talkback input. Disableing it therefore doesn't change anything.
There normally is a default setting. And also enabling talkback lowers the volume of all channels going to the phones. So I would suggest to disable it while testing.
22
touringen wrote:
Really weird!
That is helpful! Let us check this again. But also tell us which of the three existing UFX II you have. You see it in the FUT: USB 26, 114 or 206.
Yes, I just did that. No changes.
That is helpful. Let us check this again. But also tell us which of the three existing UFX II you have. You see it in the FUT: USB 26, 114 or 206.
It’s the USB 114 model.
25
Ok, don't waste your time with this anymore. Most probably this is a firmware bug that we try to fix quickly.
Sounds promising! Thank you for looking into this!
27
Error found and fixed. New Firmware Update Tools will be available soon.
Brilliant !
29
The firmware updates with a fix are now available for download.
