Topic: Updating macOS - advice requested
I'm preparing to update a 10.15.7 Catalina daily production mac to Monterey (I hang back as long as poss!).
Been forced to because of new software requirements. Currently happily running a UFXIII without any issues whatsoever - no glitches or strangeness, just smooth sailing.
Is there anything I should watch out for in terms of the update - eg the UFXIII will require a new v3.31 driver, should I uninstall the old v3.223 driver before updating to avoid any issues? Anything else? All the Mac chatter on here has made me nervous! Thanks.
2 (edited by waedi 2024-02-14 14:51:48)
Re: Updating macOS - advice requested
No worry !
I can only tell from my own experience, I did upgrade thru several MacOS and had no issues regarding RME interfaces.
The new driver will overwrite older versions, just install as the readme tells.
your computer was working well before then most probably it will work on perfectly fine.
The only true protection would be to backup your HD on a external bootable drive.
Cheers waedi - much appreciated
