Topic: Fireface 802 optimising Guitar with Amp Plugins
I have a collection of various guitar amp sims e.g. S-Gear, BIAS FX, Amplitube, etc. I've never been happy with the sound of the clean and edge of breakup patches. When watching various YouTube reviews, I am becoming more and more convinced they are less than truthful in how they are getting some of those sounds, particularly the cleans - the sounds they get are rich, full of life, sound great. My sounds (new strings) using the same patches are dull, lifeless, uninspiring. I would never buy this product if the sound demo'd was like this. Don't get me wrong, there is some life there, it's just that the patch sound I get is nowhere as 'good' as what I hear in the review. Every review.
I currently plug my guitar (Strat/LP/Suhr) into the front left (channel 9) combo socket. In TotalMix Hardware Input, I select 'Inst' for this channel - the Fireface front pannel '48V/INST' led lights up. I play the guitar and note that the input meter in TotalMix is low, so I turn up the Fireface Gain knob till a reasonable signal is seen, keeping a good bit away from 0.
In Cakewalk (Bandlab) I create an audio track, select its input as Fireface channel 9 (L), and for testing purposes, the output straight to Fireface AES (Fireface connected to my Eve SC203 speakers digital input).
In the plugin, the only change I make is to adjust the input and output volume (for youtube comparison testing, I don't want to change the patch sound).
Is there something I'm doing wrong here?
Interestingly, there is currently a lot of noise in YouTube regarding how to optimise this very issue. Basically, instead of the (what I thought) standard 'turning the audio interface gain up till it clips, then turning it back for a little headroom' - instead of doing that, it is suggested that we now set the interface gain close to 0. Why? because it turns out that most/all plugin makers optimise the guitar signal from the interface with a 'low' gain setting. This is bizarre since it's counter intuitive. However, when they demo'd the issue using the 'normal' method using a clean plugin patch, the sound was very pushed/crunchy. The thing is, I would realise this instantly as a problem with the interface's gain and back it off a little, so I'm not sure I have that same issue (at least for clean patches).
S-Gear seems to be a bit different here, in that it does require a high(er) interface gain setting before its input and output meters registers a reasonable signal that you can hear.
