Hi Alex.
It is no problem to combine any recording interface with an ADI-2 Pro FS R BE or even ADI-2/4 Pro SE reference converter.
Model differences and nice features (except ADI-2/4 Pro SE) see this blog article: https://www.tonstudio-forum.de/blog/Ent … ses-EN-DE/
You can connect the ADI-2 Pro or ADI-2/4 Pro SE via AES or ADAT, there is no quality degradation.
See my blog article about the integration into your setup:
Also, AES provides galvanic isolation and would allow for even longer cable runs in the studio.
ADAT has IMHO two advantages:
- you do not need the breakout cable (one cable tree less)
- small diameter optical TOSLINK cable, can be up to approx 16 m long (although specs tell 10 m)
But if you needed the two ADAT ports for other stuff, then use AES.
I would think twice and decide to go straight with a combination of UFX III and ADI-2 Pro FS R BE.
Reason: you have more possibilities / options to expand in terms of additional hardware through MADI.
Two ADAT ports can quickly be too few especially if you want to have the freedom to be able to record in double speed.
Look at the 12Mic at double speed, for 12 analog inputs you need already 3 ADAT ports for recording at double speed.
The UFX II / UFX III are in a price range where I would say, this is most likely your last / final recording interface, as it gives you everything you might need. Therefore it makes sense, to choose the UFX III with MADI to be future proof for greater sustainability after purchase.
Another reason is, that you can make use of not used MADI ports for creating submixes and recording them via loopback recording. If your ADAT and AES ports are already in use, then this is not possible.
My proposal for you is such a setup that I have. You do not need all of these devices, I only wanted to give you an idea.
Basically, I talk about: UFX III, ARC USB, ADI-2 Pro FS R BE, the rest is an option.
Also nice in such a setup is ADI-2 Pro FS R BE as SRC (sample rate converter for DAT or some guitar emulations)
PC----ARC USB
| TV+
| USB3 BluRay+ \
UFX III+---ADAT1 OUT-----------TOSLINK Switcher-----Optional: ADI-2 Pro FS R BE #2----->e.g. HiFi as Main Out B
| | \ central D/A conversion for different sources in front of HiFi
| | +---ADAT2 OUT--------->ADAT IN---ADI-2 Pro FS R BE+---AN1/2 OUT---->Monitors (Main Out)
| | +---AN3/4 OUT---->Phones
| Optional: AD/DA Converter +---AN IN<---Analogue Device
| | +SPDIF<----SRC----DAT or alike
| Optional: Mic Preamp
+MADI+
OM4
My setup as an example:
Blog article about UFX III with some photos, the link mentioned above already:
https://www.tonstudio-forum.de/blog/ent … iii-en-de/
Setup Diagram: https://www.tonstudio-forum.de/attachme … -v002-jpg/
Very future proof...
