Topic: Blank Check Failed error while upgrading the firmware from 318 to 320
I got a Blank Check Failed error while upgrading a Babyface Pro firmware from 318 to 320.
Does anyone know how to fix it?
Thanks in advance.
RME User Forum → FireWire & USB series → Blank Check Failed error while upgrading the firmware from 318 to 320
Thanks in advance.
Use a different USB cable, a different USB port, and finally a different computer to perform the update. If everything fails the BF might have an issue in itself.
Thanks, m8. I upgraded the firmware at last with a new pc.
