AdamPi wrote:Hello,
I would like to go directly from the microphone preamp into the AD converter.
Can I then record directly into the DAW from the ADI-2 via USB?
I have often read that one should use a proper audio interface.
Can someone explain to me why?
Thank you!
You need a device from the ADI-2 * series of devices which has
- USB port
- Analog input
This boils down to these devices:
- ADI-2 Pro FS R BE
- ADI-2/4 Pro SE
For pure recording this is sufficient, but if you want more flexibility for your monitoring and additional features you should better get a recording interface with digital mixer (TotalMix FX).
There are many different models available that differ in
- the type and number of ports
- features
- digital ports / possibilities for expansion (AES, SPDIF, ADAT, MADI)
If you are a fan of the ADI-2 series of devices, then you can also combine it with a recording interface.
Then you have
- a recording interface with the best features for routing and "what not" (incl. TotalMix FX) and
- the ADI-2 Pro FS or ADI-2/4 Pro FS for the monitoring section with its special / unique features.
I wrote a blog article describing the differences of ADI-2 DAC/Pro models and how to integrate them into your setup:
And regarding clock synchronization please look here:
https://www.tonstudio-forum.de/blog/ent … ios-en-de/
This is also no problem and has a nice feature .... While we are at it, the ADI-2 Pro (also DAC) series of devices use their own clock for AD/DA conversion even if they are clock slave, so .. whatever clock signal you get, Steadyclock FS takes care of removing any clock jitter and finally the internal FS clock is being used for the conversion.
