Topic: ADI-2 Pro pre Eq&Vol Digital Out in USB Mode for TC Electronic Clarity
How can I output a clean audio signal (without EQ and pre-volume adjustments) from the ADI-2 Pro's digital SPDIF output to monitor it with a TC Electronic Clarity M?
I'm currently only able to monitor the main output, which is post-volume and EQ, making it too attenuated for volume monitoring purposes. What steps are needed to send a clean digital audio output from the ADI-2 Pro while in USB mode?
Re: ADI-2 Pro pre Eq&Vol Digital Out in USB Mode for TC Electronic Clarity
I had the same problem until I changed the ADI-2 Pro from multi-channel to Stereo. Then, with the DIGITAL OUT set to default, it follows input selection, i.e. USB or whatever you use.  It is def pre-fader, which was my biggest concern.  I don't use EQ to feed my Genelec monitors, but do have EQ for my Beyer headphones... Clarity still functions normally.
Hope this helps...
_____________________
Eric Seaberg • San Diego, CA • USA
A.E.S. • S.M.P.T.E. • S.P.A.R.S. • I.E.E.E.
Thanks! That did the trick.
I had to disconnect my mac from the adi-2 temporary, otherwise CC-Mode was grayed out.
