Topic: Implications of +13 and +19
I have UFX III as well as ADI-2 pro and am not sure when to use +13 vs +19 (vs +24 ADI). I'm not sure which is optimal from a SNR and distortion perspective. Here are my primary use cases:
1. Sending audio from DAW into 500 series gear and returning. In this case I send out and return at +19dBU because the extra level really helps drive some of the analog gear the way I want it to so I suspect that is optimal
2. Using clean outboard or onboard mic preamps I'm really not sure if I should use +13 or +19 for LDC/SDC/Dynamic mics
Here is my thinking ripe for correction..... I don't know which ADC chips are used but many are ESS for example show ~3.2V for 0dBFS. So if I'm set say to 19dBU that's about 7V (or do we lose 6dB if signal goes unbalanced?). I think this means it is getting padded if I'm in the right ballpark with the ADC chip. Since the output amplification stages of DAC are probably different it is likely really up to the implementation. I guess the mic question will come down to the mic pre SNR at the required drive level and probably can't be easily answered...
Anyways, I'd love to understand more or at a minimum have a good rule of thumb
