Topic: [Solved] RME ADI-2 Dac one channel low volume
The right channel sound strange it has much lower volume and some kind of strange echo, anyone experienced the same thing?
Re: [Solved] RME ADI-2 Dac one channel low volume
Try a reset:
While powering up, push and hold the VOL button (NOT the VOLUME dial) and Encoder 1, until you see the message: “Reset done.
User Setups and EQ Presets are not deleted.
Or a full factory reset:
While powering up, push and hold the VOL button (NOT the VOLUME dial) and Encoder 1 and Encoder 2, until you see the message: “Reset done“.
3 (edited by unpluggged 2024-03-23 11:04:35)
Have you activated M/S processing by accident?
4 (edited by sven-ake.samuelsson 2024-03-23 16:33:31)
Thank you, problem solved,it was my mistake, i hate this fucking thing but it sound so good i need to keep it
5 (edited by KaiS 2024-03-23 22:38:40)
Check the ADI-2 Remote App, it simplifies the usage.
