Topic: Input Channel named Listen & won't let me change routing
I have a small issue where all of a sudden input Channel 2 on total mix has changed its name to Listen (highlights it in blue) and has no output assigned on the bottom of the channel.
When I click on the bottom of the channel to assign the output, nothing happens and I get no output drop down menu.
When I try to change the name in channel layout settings it doesn't change once I hit OK.
I'm wondering have I hit a setting for this channel? If so I can't seem to find what it is.
When I plug something into input 2 I do get a signal however I can't change the output routing for it.
I have tried resetting the mixer to no avail.
Anyone had this happen to them and any ideas how to reset?
Thanks.
Re: Input Channel named Listen & won't let me change routing
Totalmix menu Options - Reset Mix - Total Reset
Screenshot, please.
4 (edited by oli77sch 2024-04-27 09:19:25)
Hi marcdez
EDIT: found it!
Menu Options - Settings - General - Listenback
Is there AN 2 selected? Set it to 'None' once.
My original reply:
I assume the CUE / PFL is in use, maybe accidentally?
What interface model, firmware, driver version, Totalmix version, computer OS?
Do you have MIDI equipment / connections in use?
Thankyou oli77sch
Thats sorted it!
I really appreciate the help and quick response.
oli77sch wrote:
Hi marcdez
EDIT: found it!
My original reply:
