Topic: Total Mix Routing Problems
I am in a need of a little bit of help cause I have trouble figuring out how to Route my Signals with my Specific Setup.
For a long Time I used the RME Fireface UC without having much Problems. Later I added a Pulse 16 from Ferrofish to have some more IOs cause I am running some analog Gear.
That took a while to figure out the Routing but it seemed to work.
But because I wanted to use all 16 Channels of the Ferrofish I upgraded to a RME Digiface USB but still want to use the Fireface so I have 24 IOs in Total.
I figured out how I can use all the Pulse 16 Channels as Hardware Inserts in Pro Tools and I hooked everything up to my Patchbay. But I cannot figure out how to use the Channels from the Fireface. I can see that Signal is going into the Fireface but nothing is coming Back to the ADAT Inputs from the Digiface.
I guess I may only have done something wrong cause I have to do the Routing in 2 different Total Mix FX Windows.
I will provide some pictures of my Total Mix FX Windows shortly. Maybe some can point me in the Right direction where my Problem is.
Heavy Greetz
