Re: Dangerous Default Settings for TotalMix - Gear and Ear Damage
I want to mention that the new Room EQ "Vol Cal. dB" knob in Totalmix FX is great for this purpose!
It can attenuate each output independently by up to 24dB, it disregards snapshots, and applies even when the "Room EQ" switch is turned off! Not available on the Babyface (yet?) though.
Only if you would rather not use the EQ for real use cases...
Much saver is to spend €25 for an attenuator ..
Then you have your head free and can activate / deactivate room EQ as you want.
