Topic: Fireface 800 +4dbU 2 volt ?
I measured the voltage at the output of my interface.
At 1 kHz, +4 dBu to 0 dB:
Between shield and cold, I measure 1.28 volts.
Between shield and hot, I measure 2 volts.
I tried this on other outputs as well.
Shouldn't both measurements be 1.28 volts?
Thank you
