Topic: Digiface Dante channel order
Hi All!
I have a Digiface Dante. This is a fantastic Dante/Madi gear, but a have a question.
Is it possible to change the order of the channel?
Now instead of  1-64 Dante 65-128 Madi for instance: 1-64 Madi, 65-128 Dante.
All the best!
Re: Digiface Dante channel order
Sorry, not possible.
I wonder whether you are asking because of Pro Tools big_smile There is a workaround: you can route the MADI input channels directly to Dante output channels (of course also muting the software outputs) and using Loopback you will have them on Dante input channels. It is complicated, but it works.
It would be great to have the possibility to choose which channels to send in the 64ch Asio driver.
Is there a way to get the madi channels via USB without routing the Madi inputs to dante outputs with loopback.
Cause it sacrifices Dante inputs.
