Topic: note on CalDigit TS3+, RME MADIface Pro, Short Safety Offset
Just making a post about something I noticed today, in case anyone else stumbles across this issue.
I'm using an RME MADIface Pro with a CalDigit TS3+ dock, a minimum-spec m1 macbook pro, Ableton Live, and MaxMSP.
When both Max and Ableton are open, and the interface is plugged into the red USB, Short Safety Offset must be off or else any playback channels that are sending signals will cause single-sample clicks in the corresponding input channels.
When the interface is plugged into any of the green USBs, Short Safety Offset can be on.
This isn't an issue if Ableton and Max aren't both open simultaneously.
This here may be why this is an issue: https://www.reddit.com/media?url=https% … 51a39f5985
