Topic: Cheap DA converter does not work with RME UFX III
I got this cheap (Chinese) DA converter that works on my TV, but I can't get it to work with my ADAT outs on my UFX III. What I tried so far was to connect it to both of my adat outs and I also tried setting optical outputs as Spdif, but all I get from it is some crackling static. Besides connecting to with my mixer as a line in signal I also tried to connect it as a tape-in input (this is presonus SLIII mixer) and I also tried to connect it as an aux in for my electronic drums module. Different kind of static there, but still static.
The static also changes when I change sample rate, but again, it just remains crackling.
On the other hand, with my TV, it is just plug and play, I get the sound out of it immediately.
Is this DA converter simply not compatible with UFX or am I missing something here?
PS
The crackling noise decreases as I utilize faders in total mix when sending out the signal.
