Dorrus vdv wrote:Thanx Ramses
Is it worth to upgrade my UCX 1 for the FireFace UCX II, is it soundwise noticeable and is the improvement audible?
Sound wise, you need to find this out yourself.
RME performs transparent conversion, so do not expect some "mojo jumps".
Maybe some subtle changes because of the different combination of DA converter and analog stage behind it, which brings the converter signal to (different) line levels. Some devices (the reference converter) offer to select different A/D and D/A filter. But also these are no night and day differences. Only subtle one. You should perhaps read KaiS findings about certain D/A Filter to better separate shakers from other instruments in the stereo panorama.
If it is something like this, what you are after, then you should perhaps check out the ADI-2 Pro FS R BE connected to your UCX's ADAT (optical SPDIF) port, to also get galvanic isolation.
The improvements of the UCX II over UCX you can read here, feature-wise:
https://forum.rme-audio.de/viewtopic.php?id=33222
Also good, the combination of recording interface (also your UCX) and ADI-2 Pro FS R BE (or ADI-2/4 Pro SE).
See some of my blog articles:
The UFX III is interesting if you plan for a longer time (long-term investment) and might want to connect more devices, be it converters or preamps. It also offers more analog I/O where the number of ports doesn't shrink with higher sample rates (e.g., double speed). Another advantage, you can keep and further develop your setup in TotalMix FX. If you upgrade later you have to change everything and build-up everything newly.
Ideal is the combination of UFX III, ADI-2 Pro FS R BE (or ADI-2/4 Pro SE). It gives you enough headroom for a long time.
And it's nice that the UFX III got the converter of the older ADI-2 Pro FS reference converter.
Depends on your current and future demands, interests, budget .. as usual :-)
But all this doesn't solve your issue, that your PC might have some limitations in combination with Kontakt.
Where I am not sure whether we are talking about real limitations.
If you play with a master keyboard through a Kontakt instrument, then you do not have the full RTL.
The A/D part and transmission over USB is not applicable with such a use case.
