And is it OK, if I plug the condenser microphone before switching FF800 on (with phantom power set on)?
kubrak, with all respect, but: - No!?! ("...while phantom power is active causes a high voltage surge...")
Or is it possible to set phantom power on/off using MIDI (in standalone mode)?
Should work. snippets from FF800 manual:
28.8 Stand-Alone MIDI Control
When not connected to a computer, the Fireface 800 can be controlled directly via MIDI. To
unlock the special stand-alone MIDI control mode first activate MIDI control in TotalMix (En-
able MIDI control), then transfer this state via Flash current mixer state into the unit. Turning this
mode off is done in the same way, but with MIDI control deactivated.
Control is performed via both the Mackie Control protocol and some standard MIDI functions
(see below).
Page 80:
In stand-alone MIDI mode, the Mackie Control protocol also gives access to some settings of
the Settings dialog:
-> Simple Note on/off messages:
F9 Phantom Power Mic 7 (Note:D4, decimal:62, hex:90 3E 00/7F)
F10 Phantom Power Mic 8 (D#4 63 90 3F 00/7F)
F11 Phantom Power Mic 9 (E4 64 90 40 00/7F)
F12 Phantom Power Mic 10 (F4 65 90 41 00/7F)
“Do It For Her”
