Topic: [Solved] Babyface Pro with Cranborne 500ADAT
I recently purchased and installed a Cranborne 500ADAT. It is connected to my Babyface Pro FS via ADAT. This should provide 8 channels of ADAT as it is set to 48K. When routing pre-recorded audio out of my DAW to the unit, to pass through 500 series modules, the audio goes out to TotalMix (meters move and audio can be heard)... but it does not return to the DAW (Ableton Live 12 or Cubase 13) and the inputs do not show any signal, even though the outputs do.
I thought I was doing something wrong, so I contacted Sweetwater support. During a remote session to my Mac (Sonoma 14.5) we discovered that in 'Audio MIDI Setup' in macOS, only AS1 and AS2 are active.
The other 6 ADAT channels are present, but the faders on them are locked (unusable). I was told this implies that the Babyface is in SPDIF mode.
I'm wondering if anyone has any suggestion on how to resolve this.
Steps taken so far:
Confirmed 'Optical Out' is set to ADAT in Fireface USB Settings Options section
Confirmed 'Clock Mode' Sample Rate is set to 48000 Hz in Fireface USB Settings with 'Clock Source' set to Optical In
Confirmed 'Current Clock' displays ADAT In
Confirmed 'Input Status': ADAT | Sync | 48kHz - in Fireface USB Settings
Updated Babyface Driver
Attempted to update Firmware, but was on current rev (forced it anyway)
Disconnected/reconnected ADAT cables
Disconnected/reconnected USB cable from Babyface to Mac
Multiple reboots
Confirmed dip switches on Cranborne 500ADAT are set to INTERNAL and 48K - making 500ADAT the Master
Any ideas or advice would be appreciated. Thanks
