grezure wrote:I recently switched to a Babyface Pro FS. I had an ongoing project and was using a first gen Focusrite Scarlett 2i4. This is quite a big project, and I was running the Scarlett at a buffer size of 128. I had no pops and clicks. Now that I switched to the Babyface, the exact same project with no additions at buffer size 128 is popping and clicking really bad. I had to switch to 512 so it was smooth again.
I'm on Windows 11 and both are using ASIO. Babyface is ASIO Fireface USB and Scarlett was Scarlett USB ASIO.
I would expect this interface to have better performance than the Scarlett. Do you know what I might be missing that doesn't allow me to run an equal (or better) buffer size?
Please let me know if I can provide any more info that helps.
TIA
A system with that CPU should easily be able to work with a 188 channel interface like the UFX III
up to a 390 channel interface like the HDSPe MADI FX.
Try all USB ports
Did you try already all USB2 and USB3 ports on your system?
Normally, all USB3 chipsets should be 100% backward compatible to USB2. Each USB3 port has separate pins for USB2.
Usually, there are no USB chipset issues under USB2 I read here from RME on the forum, USB3 is more demanding.
But what can always happen is that two USB ports share the same USB controller, and this can be bad for a recording interface. Therefore, disconnect all USB hardware that you do not require and try all USB2 and USB3 ports for connecting the Babyface and check whether the situation becomes better with one of these ports.
If that does not help, check the settings and DPC Latencies as described below. But here is a recommendation if you have a Desktop PC and a free PCIe (2.0 x1) socket which does not share PCIe lanes with another PCIe socket or M.2 cards:
To really ensure that the recording interface gets a dedicated USB controller for itself, I would suggest getting an additional USB3 PCIe card for your system with FL1100 USB3 chipset on board. This card/chipset s known to support USB3 and USB2 recording interfaces very well. Its drivers are integrated with Windows 10 and 11 already and work with the more efficient interrupt scheme called MSI (Message Signalled Interrupts). This hard here:
https://www.sonnettech.com/product/alle … 4port.html
Check DPC Latencies
Did you use LatencyMon to check whether your PC is suitable to handle real-time audio processing?
https://www.resplendence.com/latencymon
Under Tools -> Options -> Tab "General" set to measure
[x] Interrupt to user process latency
Run it on a freshly started and IDLE system for at least 5–10 minutes.
Wait a couple of minutes after login until startup- and login- related processes settled, and CPU activity goes down.
Do not start any other application as it induces already a DAW load to your system.
During measurement, avoid mouse and keyboard activity.
Energy Profile
Do you use High-Performance or even Ultimate Performance energy profile?
See: https://www.howtogeek.com/368781/how-to … indows-10/
powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61
Windows Memory Integrity (VBS) disabled?
Is Memory Integrity (VBS) disabled? It is a security feature, but is badly "overdesigned" for end users' demands.
Therefore, Microsoft has blocked installation of Win11 on older systems where it is enabled by default because
there is not enough performance left. But even on modern systems, gamers (who also need a fast reacting and
performant system) complained about lower fps so that Microsoft had to invent the gaming mode which disables it.
https://www.tomshardware.com/how-to/dis … windows-11
BIOS Settings, disable energy savings
Is your BIOS tuned to turn off energy saving to get a quicker reacting system with lower DPC latencies?
- Disable C-States or set to C0: keeps CPU cores active even if they are not in use, reduces DPC latencies a lot
On some systems, you can also disable P- and T- states, to keep the CPU running at a constant frequency
and to disable thermal throttling.
- Disable C1E (enhanced halt state) so that the CPU core does not lower voltage and clock frequency to save even more power
- Enable Turbo (allows CPU to boost its clock speed beyond the base frequency when thermal and power conditions permit)
- Keep EIST enabled, you can control CPU clock speed by Windows Energy profiles.
- Disable "Spread Spectrum" to avoid changes of the CPUs clock frequency, as a settling time is required for the new clock frequency to stabilize. This can cause some µs of lag which we better save for lower DPC values.
Optimization for background processes
Check whether this brings you benefits. It sets the time quantum of the process scheduler to a longer and fixed time quantum like in Windows Server to be able to work on processes more efficiently:
https://www.tonstudio-forum.de/blog/Ent … es-or-not/
Backup before doing changes
It is highly recommended to perform a backup of your system and - if you change BIOS settings - to make photos of your BIOS settings before changing anything.
Macrium Reflect Home is an excellent disk imaging software.
I would purchase the tool as the demo version is lacking two important features.
- RDR (Rapid Delta Restore, see https://blog.macrium.com/focus-on-macri … 3a244a0fb)
- incremental backups
With Rapid delta restore, only the deltas/changes are restored which increases restore time massively.
I can restore a 1 TB SSD filled with around 850 GB of data in less than 15 minutes.
So if you perform a few changes and want to go back to the previous state, it does not take much time and it is reliable.
I would not trust Microsoft tools, they are lacking such features and helpful options.
If you buy four Macrium Reflect Home licenses, then you get 2 for free. Ask your friends and in family, then you save 50% of the price for one license.
