Topic: Sample rates
Basic question, please help.
I was playing around with sample rates. I drive active speakers through RME ADI 2, using Tidal.
-the audio midi interface on my Macbook gives an option to sample at up to 768 kHz on the RME output
-Tidal max is 192 kHz
When I use the 768 kHz setting I naively thought that it would give higher quality sound but it's terrible.
When switching the sample rate back to 192 kHz, the sound is as it should be
Can some please tell me - is it best to match the sample rate on the Macbook output to the sample rate of that particular track in Tidal (ranges from 44.1 to 192)?
Why is this - is the DAC trying to oversample if its rate is higher, which degrades the audio through the speakers?
Thanks.
