Topic: RME TotalMix FX Fireface UCX Disconnected
Hello
I've had Fireface UCX for about ten years, and it's always worked well. In late August, it stopped working and I could not reinstall it on my old Imac os X 10.10. 5. Someone advised me to buy a new one, which I did, and I can't get it to work there either. Fireface USB settings seems to see the hardware and RME TotalMix FX: Fireface UCX  is up and seems to work, but it is always disconnected! Why?
Sincerely
Tryggvi
2 (edited by waedi 2024-09-03 01:11:48)
Re: RME TotalMix FX Fireface UCX Disconnected
How can it be seems-to-work ?
Play music and send it to the headphones, can you hear the music or not ?
New versions of Totalmix can open without interface, it shows disconnected.
The Fireface Settings is showing a number of errors top right in the window ?
If there is a number of errors, that mean USB errors, your USB cable might be broken.
3
Did you change the unit into Class Compliant mode? See manual chapter 23.3. and 33.
Thank you very much for your help. I tried many things, for example I set the sound card to Class Compliant mode and then saw that it worked, but had no connection to TotalMix. Finally, after coming across a discussion here about the latest driver from RME not working with OS X Sonoma, I decided to download the 333-3 driver instead, and it works.
The previous driver was 4.14 ?
Sounds more like the UCX wasn't updated to the DK compatible firmware 49.
