Topic: Do I even need to use TotalMix?
My system seems to have collapsed after I started mucking around with TotalMix today; perhaps someone here could help. It ran perfectly (well, almost, more on that later), for 7 years, until I felt the need to open TotalMix for the first time today and change settings.
I think the first thing I need explained is... Do I even need to use TotalMix? Humour me, and assume that I don't want or need any of its fancy routing and submixing. Can I therefore ignore it, or does it need to run in the background as part of the driver?
The concept of my system is that the computer with the RAYDAT card is basically like a 32-track tape machine. I link the RAYDAT to 4 x blackface ADATs, and they are connected to a TASCAM M-600 32 channel mixing console. The DAW software is Nuendo, and I have always configured it so that Ins and Outs are routed on a 1:1 basis - ADAT In Ch1 goes to Mono In 1, ADAT In Ch32 goes to Mono In 32; Output 1 goes to ADAT OUT 1, Output 32 goes to ADAT OUT 32. I could also route stereo files to stereo out pairs when required. I mix in the analog domain on the console, either to 1/4" tape or DAT (or both simultaneously). A setup like this is a fairly old-fashioned approach I concede, but it works fine for me and the type of music I record.
So, since this is my need, do I have to use TotalMix? I've managed to ignore it until today, and would like to keep ignoring it once I fix my problem.
And now to my problem. Over the past few months, I noticed that Outputs 1 & 2 on ADAT 1 were low in level, in fact about half volume. I assumed it was just worn out electronics on the ADAT, and today I got around to installing a replacement unit. Then I discovered that the same problem continued. I conducted a range of tests with test tone, and concluded it was not the ADAT unit, or the console, or any wiring. The fault had to be either RAYDAT hardware related, or Software. I looked at software first, which brought me to TotalMix.
After moving some faders, I was able to get the levels on ADAT Ch 1&2 back to normal, however my victory was short-lived as everything else seemed to turn to TotalShit, culminating in the software icon itself disappearing, and now no outputs from any channel at all.
I'm going to reinstall the HDSP driver and have another crack at it, but if anyone could give me some ideas on getting back to the 1:1 chanel assignment functionality, that would be very much appreciated.
